Mitsubishi Electric Automation, Inc. announces the upgrade option of Vibration Cutting Control (VCC) via hardware to its M8 Series CNC as a solution to eliminate chip strands while machining difficult to cut material, such as stainless steel, at faster cutting speeds.
FDA/USDA certified, two, three and four post, stand-off bearing flange blocks are setting a new standard for performance and hygienics. These new stand-off bearing flange blocks now available from LM76 reduce the surface area where mold and bacteria can thrive, even from the most through sanitizing operations. Long life hybrid stainless steel Si3N4 Silicon Nitride ceramic ball bearings in stainless steel bearing blocks are coated with a smooth non-water absorbing polyamide coating certified by EHEDG, USDA, and 3-A. These FDA/washdown flange bearings employ hybrid stainless steel/ceramic ball bearings that are sealed from contaminates and bacteria via a patented shaft seal system. The seals resist water, cleaning solutions - keeping lubrication from being corrupted and evacuated.
Bearing manufacturer NKE Austria GmbH is entering into a strategic partnership with Kugler Bimetal SA, a Swiss producer of bimetallic components and tribological surface finishes. The cooperation was announced at the Hannover Messe in April 2023.
With the unique combination of a sensor system and kinematics working independently in six degrees of freedom, the Smart Flex Effector compensation module gives industrial robots a sense of touch similar to that of a human hand. It thus allows the automation of processes that were previously difficult to manage or could only be performed manually. The innovation was honored at Hannover Messe with the Hermes Award 2023, the most prestigious international industry prize. The Smart Flex Effector increases the range of applications for robots because it sensitively compensates for tolerances in real time. Users can thus automate joining process, complicated assembly movements or difficult handling tasks. The compensation module can also be retrofitted in existing robotic applications.
This year, the Hermes Startup Award goes to the Netherlands. The young company MantiSpectra from Eindhoven was awarded the coveted Startup Award for its ChipSense product by the jury.
Liebherr expands the existing product portfolio of open circuit pumps by the nominal size of 550 and as a double pump by the nominal size of 1,100 cc (1,100 cm3). Moreover, the new nominal size of 100 adds to the LH30VO family.
Leveraging Dana’s field-proven powershift technology, the eSP502 e-Transmission offers a dual-motor, two-speed design that is built on a flexible platform to enable optimized performance at maximum efficiency in a compact package. The modular approach to the transmission design allows for a single motor solution, as well as an optional power take-off, depending on the specific vehicle requirements. It recently made its North American debut at IFPE 2023.
