Ruland Manufacturing has expanded its jaw coupling line to meet the demands of high-torque applications, now offering bore sizes up to 1-3/4 in or 45 mm and torque capacities of 2,655 in-lbs. (300 Nm). These new jaw couplings are designed for use in precision systems with high deceleration and acceleration curves, such as those found in semiconductor, solar, conveyor, and warehouse automation applications.
The S-17-85 Series of “C” Frame Pull Type Solenoids from Magnetic Sensor Systems (MSS) includes 18 different solenoids to select from based on the Voltage, Duty Cycle, Attractive Force (up to 91 oz) and Stroke length requirements of the user. MSS Solenoid coils typically utilize 23 to 40 AWG (American Wire Gauge) windings with Class “F” insulation for better protection of the solenoid during longer duty cycles. Operating voltage range is from 3.0 VDC to 429 VDC, and from 5 to 40 Watts.
The KISSsoft System Module is an intuitive, versatile, and adaptable tool for modeling and analyzing entire gear systems. It is an integral part and module of the KISSsoft software and accelerates sizing and optimization along the whole design process. Considering the needs of customers, KISSsoft's goal is to assist with the migration of the existing models to the System Module and for a smooth transition, it is highly recommended to start with the current release.
As of September 23, 2024, Havlik Gear is changing ownership. Wikov Industry a.s. has acquired Havlik Gear. Wikov is a strong group of companies producing high end gears, gearboxes and complete drives for industrial and turbo applications and for railway vehicles. The company name has changed to Wikov Gear Canada Inc.
NTN Corporation is pleased to announce the expansion of our “Low Friction Hub Bearing” Series, with the development of two new products with low friction characteristics, “Low Friction Hub Bearing IV” and “Low Friction Hub Bearing V”. These hub bearings were developed to meet the needs of our global automotive OE customer-base, as they strive to make their mobility products more efficient.
The Timken Company, a global technology leader in engineered bearings and industrial motion, today appointed Tarak Mehta the company's president and CEO. Mehta was also elected to Timken's Board of Directors.
At MINExpo 2024, Continental recently highlighted solutions tailored for the mining industry, including conveying systems, digital monitoring platforms, fluid hose solutions, and more. These products are designed to withstand the toughest environments while boosting efficiency and productivity.
Today's demanding industrial applications require compact, robust connectors that can reliably transmit high currents and voltages. binder, a provider of circular connectors, now offers the perfect solution: special flange components act as plug-in partners for the PBC15 cable connector. This combination enables tailored solutions for a wide range of applications, such as in-drive technology.
Continental's CONTI NXT Multi V-belt from the ContiTech group shows it will also be possible to power auxiliary units in cars using renewable raw materials and recycled materials. CONTI NXT Multi V-belt will use tension cords made from recycled PET bottles, a textile cover layer made from organic fibers as well as rubber certified according to the mass balance standard and recycled carbon black. Overall, the belt is made of almost two-thirds of more sustainable materials compared to conventional V-ribbed belts. The CONTI NXT will be available in the spring of 2025, in addition to the conventional Multi V-belts of the Continental brand – initially in 25 different types for the most common repair needs.
Based on the proven ROBA-DS steel disk pack coupling, Mayr Power Transmission developed a weight-optimized aluminum version. Compared to the steel version, the outer diameter of this new design has been reduced by up to 10 mm; the mass and mass inertia range from 40 to 60 percent of the steel version, depending on the design and size. The performance density, however, remains unchanged. It is tailored to meet the requirements of high-speed applications, for example in the field of test bench technology.
