In KISSsoft, 97 (yes, ninety-seven!) plastics are available for calculation of cylindrical and crossed axis helical gears. The materials range from unreinforced POMs and PAs to high performance reinforced and internally lubricated materials.
Siemens Digital Industries Software and CEA-List, a technological research institute focused on smart digital systems research, has announced the signing of a memorandum of understanding to collaborate on research to further extend and enhance digital twin capabilities with artificial intelligence (AI) and explore greater integration of embedded software on both virtual and hybrid platforms.
Stock Drive Products/Sterling Instrument (SDP/SI) recently announced that they will be manufacturing specialized precision components for a new locking system in support of the U.S. Postal Service’s initiative in preventing the theft of mail.
GT and PTE Presents "Ask the Expert Live," taking place October 17-18 during the Motion + Power Technology Expo at Huntington Place in Detroit.
This year, rather than focusing on gear basics or the more technical aspects of gear design and manufacturing, we’ve decided to address some of the issues that you’ve told us are most significant to you—the things you’re struggling with, the questions you’re hoping to find answers for, and the troubles that keep you up at night.
GWJ Technology GmbH has introduced new versions of its integration modules for Solidworks, Autodesk Inventor and Solid Edge. In addition to comprehensive tooth form output in 2D DXF or 3D STEP/IGES for various gear types, GWJ also offers integration modules for its calculation solutions eAssistant and TBK in various 3D CAD systems.
Unless you work for a major network, you’ve probably never heard of them. But without the efforts of Drew
Farrow and the team at ShowFab many of your favorite Broadway shows, news programs, and broadcast
sporting events would not be possible. That’s because there’d be no colorful backdrops, no glitzy displays,
and no lights or cameras moving silently overhead.
The reason they’re silent? Nord Drivesystems whose gearmotors position the massive scenery seen
moving in and above the sets of The Today Show, Fox News, Fox Sports, The NFL Network, and
NewsNation, to name a few.
A worldwide manufacturer of many types of plastic has manufacturing facilities around the world, including one in the southeast that makes PVC stretch film. Imagine the film used to wrap meat at your local neighborhood grocery store, or that you might use to keep leftovers fresh for later in the week. Although the plant is designed for precision and automation, sometimes mechanical components derail those plans and require operator interaction to correct the components shortcomings. The clutch-brake on a turret winding system was not precise, which not only required operator interaction but also caused downtime. Replacing the dry clutch brakes with Force Control Oil Shear clutch brakes eliminated downtime, increased accuracy and repeatability, and slashed operator involvement – all while increasing throughout.
The Canadian Manufacturing Technology Show (CMTS), Canada's largest industry event, makes its return at its new home – the Toronto Congress Centre – from September 25-28, 2023. Over 500 suppliers and original equipment manufacturers (OEMs), more than 8,000 manufacturing professionals and 250,000+ square feet of manufacturing excellence, housing 500,000+ pounds of live equipment are featured.
By definition, a spherical roller bearing (SRB) is a rolling element bearing that permits rotation with low friction and permits angular misalignment. SRBs consist of spherical rolling elements, an outer ring, a cage as well as an inner ring with two raceways inclined at an angle to the bearing axis. SRB technology has landed the component in unique applications including high pressure grinding rolls (HPGRs), pipelaying ships, Ferris wheels and even a Cold War–era marine espionage mission.
