We’ve recently completed a major redesign of the powertransmission.
com website.
I know what you’re thinking. Big deal, right? Websites are redesigned every day. It’s not really news. You’re right, of course. We’re in the news business, and when companies
send us press releases about their newly redesigned websites,
our first instinct as editors is to respond the same way.
So what. Big deal. Moving on.
One of the key challenges in the mining
industry today is maintaining throughput
in the face of ore grade quality that
has declined by 40 percent in the last
decade.
Experts gathered at the 9th CTI Symposium to discuss the challenges of reducing noise, improving energy efficiency and meeting the changing demands of the marketplace
Machine and equipment manufacturers
today are feeling more pressure
than ever to reduce costs without sacrificing
machine performance — a balancing
act difficult to achieve. OEMs often overlook a simple solution that can have a positive, long-term impact
on profitability for themselves and
their customers, i.e. — the elimination of bearing lubricant.
