In this paper, the models for different power loss sources in transmissions from literature are applied and compared, which form the two methods - ISO 14179-2 and the joint model to estimate the power losses in a transmission. A 2-speed transmission in an electric vehicle is used as a case study to compare the two methods and validate them with experimental data.
Lower-cost motor technologies exist that can be an attractive alternative to neo-based BL PM motors - and are not subject to unpredictable supply chains
Whether you design, build or maintain industrial equipment, it is likely you have encountered many types of bearing grease over the years. Lubrication plays a crucial role in virtually all operations, and certain key characteristics allow grease to perform its job better in demanding applications.
They're like real fingers, able to pick up hard stuff, a spark plug or a metal pipe connector, and pick up soft stuff without breaking or smushing it: an egg, a loaf of bread, a donut.
