If torque conversion with high gear ratio, compact installation space and 90-degree axis-crossing angle is needed, often worm gears are used. Due to their high power density and sliding speeds within the tooth contact, frictional heat and thermal stresses are higher compared to helical, bevel and hypoid gears, and thus the thermal load capacity of worm gears is lower.
The industrial arts of mechanical engineering are all around us and seen in many forms and technologies. Of greatest interest is how these wonders are designed, constructed and used. From the smallest home appliance to the behemoths used for outsize building and excavation projects.
Motion control systems often combine high power drive signals in close proximity (or even within the same cable) with lower level signals, like encoders. You will often see ferrite beads added around cables; their effectiveness in minimizing noise is greatly affected by how they are deployed. This involves which signals are grouped, what are the drive characteristics, and how shielding and grounding are handled in the system.
