Motion control systems engineers work chiefly in two well-defined areas: 1) new designs and 2) redesigns or retrofits. This article examines the best approach for each option.
Next time you are strolling across a manufacturing plant, check out the hardware on the ground. Shop floors are nothing but cables plugged into machines, cables plugged into computers, cables plugged into other cables...
elements on the machine tool.
Norkol Converting Corporation is one of the nation’s leading independently owned
converters and distributors of commercial printing papers. The company has full production capabilities and state-of-the-art machinery for winding, trimming and sheeting. The company utilizes traditional slitter re-wind equipment that unwinds, slits and then re-winds paper to new dimensions. These conventional re-winders, while typically producing new widths of paper with clean cuts, work at an inefficient, slow pace.
