One of the key challenges in the mining
industry today is maintaining throughput
in the face of ore grade quality that
has declined by 40 percent in the last
decade.
Experts gathered at the 9th CTI Symposium to discuss the challenges of reducing noise, improving energy efficiency and meeting the changing demands of the marketplace
Machine and equipment manufacturers
today are feeling more pressure
than ever to reduce costs without sacrificing
machine performance — a balancing
act difficult to achieve. OEMs often overlook a simple solution that can have a positive, long-term impact
on profitability for themselves and
their customers, i.e. — the elimination of bearing lubricant.
