If you’re an electrical engineer
you know how an electric motor works; if
you aren’t, it can be extremely
confusing. Therefore, here’s the simplified explanation (or the “how
an electric motor works for dummies” version) of how a four-pole, three-phase
AC induction motor works in a car.
Pack Expo takes place November 6-9 at McCormick Place in Chicago. With 2,100 exhibitors, it’s the world’s largest most comprehensive processing and
packaging trade show in 2016.
Here’s what we know about Tremont, Illinois: It’s a small village in Tazewell County, (population 2,400+), holds an annual summer turkey festival
(quite popular) and the courthouse is a famous historic site where politician James Shields challenged an “up-and-coming” lawyer named Abraham Lincoln to a duel with cavalry broad swords (they showed up, but the duel never materialized). In 2016, you can add FIRST Robotics Competition World Champion to the village’s rather eccentric list of accomplishments.
When trying to find a new bonding material dispense system, one manufacturer tested a series of pumps — all of which leaked due to the abrasiveness of the bonding material. The manufacturer also had been attempting to manage shot size
manually with their previous system, and was not able to keep dispense consistent. The company searched for
a system that could accurately dispense programmed shot sizes while also eliminating the leaking issues they
had experienced with previous pumps. Graco provided a Check-Mate pump with SmartWare software, and the manufacturer is now able to automatically dispense shots of bonding material as small as one ounce without leaks.
slow speed operation.
