With the increasing mechanical power capacity of gearboxes, the thermal power limit tends to become the limiting factor. To achieve a balanced system, the gear unit needs extra cooling. Using a fan that is mounted to a fast rotating shaft is a common solution. For this solution an optimal design is investigated.
This issue, we're pleased to present our annual Buyers Guide. It's our comprehensive directory of suppliers of mechanical components, including gears, bearings, motors, couplings, clutches, brakes, gear drives and more.
