When City Scrap & Salvage experienced a catastrophic failure of the driveline between the motor and rotor of its automotive shredder, the company called on Voith Turbo for a
potential manufacturing solution.
The integration of manufacturing information into gear design software reduces cost during the design process by avoiding time-consuming back and forth between the design and manufacturing departments. The challenging task for such software is ensuring the
design engineer does not need specific manufacturing expertise. Otherwise he or she would be overwhelmed and not use such a feature.
