Bearing calculations from Timken can now be easily generated in KISSsoft for the software’s registered users. Although the data is not visible in KISSsoft, it can be used in the background for calculation and design purposes.
Growth in the global linear market is being driven by both increased demand across key industries and the clear advantages of linear motors over conventional motors. Within this segment, the contribution of ANCA Motion’s LinX M-Series linear motor has expanded the market and stands out above ball screw and flatbed motor options due to several design intricacies that simplify installation and use and push quality performance even further. Designed for function, the tubular construction of the LinX has several key benefits over flat linear motors.
Siemens Mobility is presenting its new digital business platform Siemens Xcelerator at InnoTrans 2022. Siemens Xcelerator is an open digital business platform with the ambition to create a powerful ecosystem of partners who can jointly accelerate digital transformation and sustainability in mobility at scale. By opening interfaces for all participants of the mobility ecosystem, Siemens Xcelerator helps connect the real with the digital worlds – a first-of-its-kind innovation in the rail industry.
PBC Linear has expanded its comprehensive portfolio to include Miniature Metric Ball Screw Assemblies. Building on their lead screw technology, this combination of precision-rolled screw and compact nut is driving exceptional performance from an economical package. Manufacturers of sophisticated laboratory equipment, medical devices, semiconductors, and other automation applications will find these high-precision ball screws a valued solution to their small-scale linear motion needs.
The engineering community is fascinated with big, shiny, yellow machines. Walk into any manufacturing facility around the globe and you’ll find guests huddled around the biggest, loudest, and most intimidating equipment on the shop floor. These large machines must play by the same rules as everybody else—they need to reduce energy consumption, lower plant costs, and increase productivity. Many power transmission component suppliers are tasked with optimizing this equipment.
Dontyne Gears is looking forward to IMTS to promote the company’s range of gear design services developed during COVID restrictions. Dontyne Gears continues to work with companies to complete design projects including CAD models and drawings if required. They recently purchased an Okuma Genos 5-axis to add to the Osaka Siemitsu high accuracy gear inspection center already in house for prototyping. As well as cylindrical gears it is possible to produce straight, spiral, and hypoid bevels. The work is facilitated by using Gear Production Suite from Dontyne Systems to generate tool forms, G-code, and inspection protocols which can be used by the machines.
Strength rating of bevel gears according to standards such as ISO, AGMA, etc. is executed based on virtual cylindrical gears, only modified by a few specific bevel gear factors. The rating methods of these standards also include the calculation of permissible stresses and finally result in safety factors.
Bosch Rexroth will offer a free webinar on July 28, 2022, "How Self-Contained Actuators Simplify Your Engineering." The webinar takes place 9:00 - 9:45 AM EST.
2022 marks the 20th Anniversary of SMT’s focus on providing the tools and knowledge to drive engineering innovation in gearbox system analysis. With this historic company anniversary, the company has announced the return of the North America User Forum.
