The MDX+ series is designed to be small and compact, providing a smaller yet equally capable solution compared to stand-alone motor and drive systems. It is ideal for applications with limited installation space, and its form factor is at least 20 percent smaller than that of standalone solutions.
The MDX+ servo drive is debugged by Luna software. It is meant to assist users with configuration, tuning, and troubleshooting the MDX+ family. The software and the drive are connected via USB for fast and reliable communication.
Features
• Drive and motor integration offers a compact design
• Main power supports 24-60 VDC, Auxiliary power supports 24 VDC
• Standardized frame sizes of 40/60/80 mm, covering a power range 100W to 550W
• EtherCAT, CANopen and RS-485 options
• Equipped with a 17-bit magnetic incremental encoder or 17-bit battery less absolute encoder
• Accurate Positioning and Control
• Support position control, velocity control, torque control
• Built-in brake option is available
• IP20 or IP65 options available
Applications
MDX+ series integrated servo motors have a wide range of applications: packaging, AGV, medical, logistics, textile, electronic inspection and solar.
