Moticont has released the GVCM-022-013-01 Linear Voice Coil Servomotor. This compact .875 in. (22.2 mm) diameter high speed, high force-to-size linear motor features high accuracy and high repeatability when operated in a closed loop as a DC servomotor. This brushless servo motor is clean, quiet and has long life, low mass and high acceleration/deceleration for high throughput.
This linear voice coil motor, also known as a moving coil motor or actuator is ideal for: Haptic feedback, medical devices, wafer handling, optical focusing, dynamic vibration absorption, work holding and clamping, assembly, testing, positioning, scanners, laser beam steering, laser speckle correction and filtering.
The 0.094 in. (2.4 mm) diameter shaft has a 2-56 UNC-2A thread and exerts 14.5 oz. (4.0 N) of continuous force and 45.7 oz (12.7 N) peak force with a 0.25 in. (6.4 mm) stroke. The housing length is 0.500 in. (12.7 mm) long, the shaft extension is 0.54 in. (13.5 mm) for a total length (including shaft) of 1.22 in. (31 mm). For easy integration into new and existing applications the housing and coil ends have two 4-40 UNC-2B threaded holes on a 0.375 (9.5 mm) bolt circle.
Metric series threads are available in production quantities. A complete line of quadrature linear encoders and plug-and-play servo systems including Controller, Joystick and keypad are also available.
Is there a need for a smaller or larger diameter motor, one with longer travel, or more force? Select from Moticont's extensive series of GVCM Servomotors based on diameter of the motor, length of stroke, and/or force.
