ADS Uptime (Leine Linde) is an extremely useful condition monitoring system for encoders. With local wireless service check-up or system integration with ADS Link, you have maximum flexibility to access data and diagnostics. With ADS Uptime, you can access live data and secure production uptime by making application health monitoring part of your proactive maintenance routine. Knowing things before they happen has never been easier. It was recently featured at the Heidenhain booth during Cleanpower 2023.
ADS Uptime is available with wireless connection for Leine Linde’s 800 series. You get remote access to your encoder’s data and diagnostics with Bluetooth in the associated app on your mobile device. In the app, you can customize the alarm levels and then check the data live or look at detailed information for a specific time frame. This gives you the tools to manage your maintenance activities.
ADS Link is available for use together with Leine Linde’s 800 and 2000 series encoders. With ADS Link you can integrate the ADS Uptime encoder into your company’s existing maintenance systems.
Encoders with built-in ADS Uptime will enable monitoring the most relevant data from rotary installations and motors, as well as its surrounding environment. The system has pre-set alarm levels for working environment which are potentially harmful for the encoder, as well as a customer configurable warning system to adapt the diagnostic system to application specific parameters.
ADS Uptime analyses the encoder’s condition and warns for impending faults before they occur. With early warnings of deviation it prevents the risk for potentially occurring problems. Make the encoder check-up part of your proactive maintenance routine to make sure problems are taken care of before they start to exist.
