This solution reduces system variants through standardized geared motor selections tailored specifically to application needs and a large operable speed range via variable frequency drive technology. Simplifying engineering and selection into a compact, modular design significantly reduces spare parts inventory, enables fast commissioning through plug-and-play technology, and allows replacement of individual components. The plug-in connections on the base product also enable easy maintenance, service, and installation.
When it comes to gearbox options for the LogiDrive package, two-stage helical bevel gear units or the new DuoDrive integrated gear unit and motor are available. Two-stage helical bevel gear units are made from high-strength aluminum alloy and feature an open housing option for better heat dissipation for high axial and radial loads. They excel in conveying and processing applications while providing a more efficient and reliable solution than typical worm units. The DuoDrive integrated gear unit and motor features a compact, UNICASETM housing and delivers an extremely high gear efficiency of up to 92%. These drives also feature high power density, quiet operation, and fewer wear parts for low maintenance and a long service life.
NORD’s IE4 and IE5+ synchronous motors provide some of the highest efficiencies currently available. The use of this technology in the LogiDrive system minimizes overall costs during service life, provides a faster return on investment, and maximizes system availability. When these motors are paired with the NORDAC LINK VFD, high precision regulation and increased system accuracy is achieved. This optimized combination also results in large overload capacities capable of constant torque over a wide speed range.
NORDAC LINK variable frequency drives offer quick installation and servicing thanks to their quick disconnect cable options, integrated maintenance switch, and local manual control options. These decentralized VFDs feature functional safety options, an internal braking resistor for controlled, dynamic braking, and parametrization via plug-in control modules, NORDCON software, or NORDCON app. As part of the complete LogiDrive package, NORDAC LINK supports a large speed range – enabling automation for a variety of applications such as stacker cranes, automated transports, baggage handling systems, and conveyor systems.
