Dr. Ing. Ulrich Kissling and MSc. Ing. Sandro Hauri
Wear is a very important topic for dry running plastic gears. Over the past few years, the authors have worked closely with a number of manufacturers of plastic gears to investigate the problems of gear wear in detail. Together they have developed a calculation method that can be used to predict where and when local wear will occur on a tooth flank. Their findings have also just been published in the final version of VDI 2736.
Theory of Wear and Wear Coefficient
The term “wear” is used to describe the progressive removal of surface material due to mechanical and/or chemical stress. The four main wear processes defined in DIN 50320 are adhesion, abrasion, surface break-up and tribochemical reaction.
The simplest method of measuring wear is to press a pin made of the material being investigated against a rotating ring (Figure 1).
In the plastics industry, this method is known as the “pin and disk test rig” test. When investigating plastics, this ring is usually made of metal with a low surface roughness Rz. The wear coefficient kw derived using the pin and disk test rig (Figure 2) – is defined as follows:
for use in the tooth flank:
This determines the local wear in each point of the tooth contact area on the gear. At the suggestion of the authors, this formula has been included in VDI 2736 (Ref. 1). Another confirmation of the formula’s effectiveness is that Feulner (Ref. 2) derived the same formula on the basis of measurements.
Determining the Progression of Wear
The wear characteristics can be calculated by implementing the formula (Eq. 2) for local wear on the flank in a gear contact analysis. This makes it possible to define the shape of the abraded tooth flank. Initially, this approach did not provide any usable results, if the wear — starting with a perfect tooth form — was determined in a single calculation step. The wear characteristics must be calculated step by step because the tooth form changes as it becomes worn, and therefore the load distribution moves across the meshing. Very useful results can now be achieved by running the calculation at a sufficient number of small increments. The maximum permitted wear per iterative step must be predefined, so that the iterative progression of wear can be calculated. This predefined value is critical for achieving realistic results. This recently developed calculation method has been used to compare a range of gears that have been subjected to testing and then measured in 3D.
Figure 3 shows this type of comparison using a pairing where the plastic (PBT) output gear is badly worn. The difference between the arithmetical forecasts, with and without iterative calculation, clearly shows that the wear characteristics along the flank without iteration cannot be used and it displays quite a different trend to the measured progression. A maximum interval of 1 µm wear per iterative step has been defined for the wear characteristics in a forecast with iteration. In this case, 146 iterations were calculated (the calculation took 2.5 min, using an Intel Core i7-3770). The result showed a relatively good match with the measurement.
Influence on Transmission Error
As the tooth form can now be predicted with reasonable accuracy, more detailed analyses — for example, determining the change in load distribution or the increase in transmission error due to wear — can be defined. Increasing vibrations in the meshing over a long period of time can reduce the endurance limit. This is a recognized effect of frosting and a cause of concern wherever gears are used. For this reason, being able to predict the progression of transmission error in advance is a very interesting result.
Initial verifications performed on different pairs of gears have revealed that transmission error has a tendency to decrease in the first phase of wear (“running-in phase”); however, as the amount of wear increases, this error also increases significantly to reach values that are two to three times greater.
Figure 4 shows results calculated using a steel/PBT gear pair (Figure 3). When the tooth flank calculated by wear iterations is verified with contact analysis, it is visible that the “Peak-to- Peak Transmission Error” (PPTE) is much greater when the wear has alsoprogressed. Closer investigation of the development of transmission error over the operating time shows an initial improvement in the transmission behavior. It is generally accepted that gear units which have been properly run in have a better load capacity because the load distribution has a tendency to improve during the running-in period. This “running-in effect” obviously also applies to the transmission error.
However, as the wear increases, the transmission error also increases sharply until it reaches a plateau. The fact that the transmission error does not then continue to increase, but remains at a specific, high level, can be explained as follows: a certain level of equilibrium is achieved where the tooth thickness continues to decrease but the tooth form no longer changes very much. This is illustrated by the worn flanks in Figure 4.
After the green tooth form (operating time of approximately 200 h) the following tooth forms display a similar progression, where the thickness reduces at a constant rate.
Summary
Two calculation methods are now available for calculating wear: The first is an analytical method which uses simple formulae to determine the average wear when designing gear systems (Refs. 1, 3). The second, more complex method, is integrated in contact analysis and is used to ascertain the progression of wear.
When these calculation methods are
compared with measurements taken by
test rigs (plastic and metal) and with results
from real life situations, it can be
seen that these methods produce very
usable, realistic results. Therefore, it is
now also possible to predict the effect of
a worn tooth form on the load distribution
and transmission error.
Ph.D.Eng. Ulrich Kissling
studied machine engineering
at the Swiss Technical
University (ETH) in Zürich,
followed by a doctorate. He
is the founder (1998) and
CEO of the company KISSsoft
AG.
M.Eng. Sandro Hauri was
trained as a mechanical
engineer at the Swiss Federal
Institute of Technology in
Zurich (ETH) and specialized
in Robotics. He joined
KISSsoft AG after his studies
as a development engineer.
References
