Radial spherical plain bearings play a key role in off highway equipment and vehicles
John Wallace, Vice President of Operations, AST Bearings and Steven Sanchez, P.E., BSA Certified Bearing Specialist, Engineering Manager, AST Bearings
Original equipment manufacturers (OEM) of off-highway equipment and vehicles are continuously looking for new ways to apply technology into their designs, both new and old — anything that will give their products an edge in productivity, payloads, and efficiency. The machines and vehicles they produce must endure extreme environments, demanding operating conditions, and heavy loads. Reliability and ease of maintenance are paramount; repairing equipment on-site is costly, and often almost impossible. However, many designs are built upon tried-and-true platforms that incorporate drivetrains, suspensions, steering linkages, torsion bars, connecting rods, articulated joints, heavy duty linkage pivots, and hydraulic cylinders. All of these applications have something important in common: they use radial spherical plain bearings and rod ends. Engineers have yet to develop bearings that better accommodate the combinations of movements and heavy loads these vehicles and equipment encounter, with reliability and cost-effectiveness.
Here’s what you should know about these relatively simple and extremely tough bearings found in most off-highway applications.
How they work
Radial spherical plain bearings have an inner ring with a sphered convex outside surface, and an outer ring with a correspondingly sphered (but concave) inside-sliding contact surface. The two general styles relate to the manufacturing method. Swaged style bearings are made by “swaging,” or forming, the outer ring over the inner ring (or ball). Fractured style bearings have an outer ring that is split, or fractured, in one position to facilitate assembly of the rings during manufacturing.
The bearings can be comprised of different sliding contact surface combinations, i.e. the sliding surfaces of inner and outer rings are made from different materials. Some combinations require maintenance (such as steel-on-steel), while others do not.
Comparison to rod ends
Rod ends consist of an eye-shaped head with integral shank, forming a housing and one of three options: a standard spherical plain bearing, a spherical plain bearing inner ring, or a spherical plain bearing inner ring with a sliding layer between the bore of the head and the inner ring. As a rule, rod ends are available with left or right-hand female or male threads. Rod ends can have the sliding contact surface combinations steel-on-steel, steel-on-bronze, steel-on-PTFE composite material, or steel-on-PTFE fabric.
Rod ends and spherical plain bearings share common design principles and function in the same manner, designed to handle radial loads under misalignment. Rod ends are more common in linkages and connecting rods due to their ease of mounting and adjustment. They can be selected with sliding contact surface combinations that render them maintenance-free, or the steel-on-steel style can accommodate a grease fitting, allowing for regular re-lubrication.
Spherical plain bearings, however — due to their construction and internal geometry — can handle heavier radial loads under misalignment than rod ends. They accommodate misalignment between the housing and shaft, as well as oscillating movements at slow speeds. While these bearings can handle a small amount of axial load, they should be used where the load is primarily radial.
Varieties and case studies
Maintenance (steel-on-steel) spherical plain bearings are more common in off-highway applications. These bearings have a hardened sliding contact surface on both rings. The surfaces are treated with molybdenum disulfide (MoS2) lubrication and a phosphate coating. They have both wear and corrosion-resistant characteristics. Bearings with this sliding contact surface combination require initial, and regular lubrication. The high strength of the sliding contact surfaces makes these bearings especially suitable for bearing arrangements where heavy loads of alternating direction, shock loads or heavy static loads have to be accommodated. Unless properly protected, maintenance free bearings with liners (PTFE composite or PTFE fabric) are subject to deterioration from contamination, and they are not well suited for heavy alternating loads.
Since bearings with steel-on-steel sliding contact surface combinations require regular relubrication, they typically have lubrication holes and grooves in the inner and outer ring to allow grease to flow into the areas of sliding contact. It is important these features line up with the grooves and grease fittings in the mating components when mounted.
When mounting bearings with a fractured outer ring, it is critical that the joint be positioned at 90⁰ to the main load direction, otherwise the service life will be shortened, particularly under heavy loads. The angle of tilt, or misalignment, is usually noted with the symbol α in most catalogs and can vary from 3⁰ to 15⁰. Bearing tolerances, internal clearances, and recommended fitting practices are listed in the Engineering sections of most catalogs. In the US, ANSI/AFBMA Standards 22.1 and 22.2, Series 3, covers these types of bearings.
One of the most common uses of spherical plain bearings in off-highway equipment is with hydraulic cylinders, linear actuators designed to deliver force in a single direction, because they’re effective in dealing with misalignment — a common cause of hydraulic cylinder failure. Spherical bearings are often used in the clevis style mounts of hydraulic cylinders. Deviations from the centerline of the load, introduce what is known as “side loading”. This places lateral stress on cylinder pistons, seals, bushings and rods — these components are not designed to withstand these forces, so they will fail quickly. Spherical bearings allow for some degree of misalignment due to side loading, improving cylinder longevity.
A typical excavator or backhoe has a half dozen cylinders, or more, for the bucket, boom, dipper, outriggers, steering, and other equipment and accessories on the vehicle where these bearings are used, in addition to steering linkages, shock absorbers, and pivot points.
Spherical plain bearings are available in various types and configurations to address specific loading and operating conditions, and environmental conditions.
Spherical plain bearings are available with seals to protect the sliding surfaces in severe environments. The seals are affixed to the outer ring and make positive contact with the inner ring keeping dirt and debris out, and the lubricant in. Variations in seal materials and design vary from manufacturer, but most seals are either a polyester elastomer material or a buna nitrile rubber bonded to a sheet steel insert. These plastic and rubber seals are best suited for applications where the bearings see frequent tilting or circumferential movement. This tends to keep the contact surfaces clean.
To ease assembly, and eliminate the need for spacers, these bearings are also available with an extended inner ring design. These have a slightly higher cost.
Depending on their size, most spherical plain bearings accommodate misalignment in the 5 to 15 degree range. However, higher angles of misalignment can be accommodated with a special series. This series has an increased cross section inner ring which allows for the higher angle of tilt, up to 20 degrees.
In some off highway applications shock or impact loading is common and can have a devastating effect on bearings. Most spherical plain bearings are manufactured from thru hardened 52100 chrome steel. These bearings have good wear resistance and fatigue strength. However, with their high hardness, they are susceptible to chipping, cracking, and breaking under these conditions. Spherical plain bearings manufactured from low carbon, carburizing steels, such as 8620, and processed with a special heat treatment known as case hardening are recommended in these applications. The case hardening provides an outer layer of high hardness for wear resistance and fatigue and the core of the bearing is “softer”, or more ductile, which allows the bearing to absorb impact. These bearings carry a price premium.
Loading and life
Spherical plain bearings can accommodate loads in both the axial and radial directions, with the load predominantly radial for the latter. Angular contact types are available for heavier thrust or axial loading. Loads can be in combination, and the direction constant or alternating.
Other loading considerations:
While these bearings have very straightforward construction and operating principles, calculating service life is tricky — so engineers are advised to contact the manufacturer for assistance. The values of load ratings depend on the definition used, so it’s not always possible to make direct comparisons with load ratings published by each manufacturer.
Dynamic load rating
Dynamic load rating is used for calculations when the spherical plain bearing is subject to dynamic stress. It represents the load, constant in magnitude and direction, under which a basic rating service life, expressed as a sliding distance, will be attained for continuous oscillating movement at a defined sliding velocity at room temperature. It assumes that the load acting on radial and angular spherical plain bearings and on rod ends is purely radial, and that the load acting on spherical plain thrust bearings is purely axial and acts centrically. Dynamic stresses often occur in combination: when tilting, oscillatory or rotational movements are made under load; with micro-sliding movements under alternating loads; and with loads alternating at high frequency.
Static load rating
Static load rating is used when spherical plain bearings remain stationary under load, with only occasional alignment movements. It should be considered when dynamically loaded bearings are subject to heavy shock loads.
The static load rating represents the load which can be taken by a spherical plain bearing when static contact stress of the bearing contact surface reaches the material stress limit. It is valid at room temperature and it assumes that the surrounding components prevent deformation of the bearing.
At higher temperature, it must be multiplied by a temperature factor dependent on the sliding contact surface combination. The temperature factor is the same as for a dynamically stressed bearing. It is also necessary to take into consideration the permissible temperature range for the various sliding contact surface combinations. For rod ends, this is the strength of the rod end housing under stationary load. The rod end static load ratings give a safety factor of 1.2 times the tensile strength of the rod end housing material.
Service life
The service life of a spherical plain bearing is expressed as the number of oscillating movements, or the number of operating hours, which the bearing will endure before a defined increase in bearing clearance or a defined increase in friction is reached.
The service life of a spherical plain bearing operated under mixed or dry friction conditions is determined by the increase in bearing clearance / bearing friction caused by progressive wear of the sliding surfaces, plastic deformation of the sliding material, and fatigue of the sliding surface. Depending on the application, the permissible wear and increase in friction will be different — meaning the service life which can be obtained in practice will be different, even under the same operating conditions.
The effective service life is how long a given spherical plain bearing lasts under actual operating conditions. It is primarily determined by the magnitude and type of load, as well as contamination, corrosion, high-frequency load and movement cycles, and shock. Some of these factors are impossible to determine or can only be determined with difficulty.
John Wallace is a degreed Mechanical Engineer with over 30 years of industry experience in Engineering, Manufacturing, and Quality Assurance. He has been Vice President of Operations at AST Bearings since 2003. John can be reached at John.Wallace@astbearings.com
Steven Sanchez, P.E. is a degreed Mechanical Engineer, a licensed Professional Engineer in the State of New Jersey, and a BSA Certified Bearing Specialist with over 25 years of industry experience in Engineering & Manufacturing. He has been the Engineering Manager of AST Bearings since 2013. Steven can be reached at Steven.Sanchez@astbearings.com
Lubrication
For spherical plain bearings requiring maintenance (metal-on-metal), lubrication increases a bearing’s life by reducing friction and wear, with the added benefits of reducing noise and providing a barrier against corrosion.
In order for the lubrication to be effective, the grease must flow into the load areas — the contact zone between the inner and outer ring. When the grease cannot flow into the load zone, the bearing must be unloaded in order to effectively lubricate it. Regular re-lubrication of the bearing during its operation, on an established schedule that’s re-examined when operating conditions change, will substantially extend its service life. NLGI grade 2 greases with EP additives are recommended.
Insufficient lubricant in the load zone allows for metal to metal contact and leads to premature bearing failure. Bearings with special groove patterns on the inner ring (ball) are available that increase bearing life in dirty and extreme environments. These grooves promote more efficient lubricant distribution by providing additional channels to move lubricant into the load zones. In addition, the grooves move and capture dirt and debris thus keeping these contaminants off the raceway surfaces. These bearings also carry a price premium.
For steel-on-PTFE lined (fabric or composite) spherical plain bearings, it’s important to refrain from additional lubrication. Any lubrication of the sliding contact surfaces could disturb the internal self-lubricating properties and shorten the bearing’s service life.
When operating conditions require enhanced sealing and protection against corrosion, it is recommended to fill the space surrounding the bearing with lithium-based grease.
Summary
Radial spherical plain bearings serve an important function within the off highway world, particularly in the construction, forestry, and agricultural sectors, because they’re crucial to the equipment and vehicles used in those industries. They’re key to OEMs’ ability to create reliable products that endure extreme environments. Knowing the basics about radial spherical plain bearings, and how they compare to other commonly used components, is fundamental to making good design choices.
