HS-Series Cobots
Highly versatile and portable, HC-series cobots are ideal for a variety of tasks including machine tending, material handling, packaging and light assembly. Designed to work safely with, or in the same workspaces as humans, these six-axis human-collaborative robots meet established safety standards.
Pallet Builder
Designed to facilitate fast deployment of palletizing cells, the easy-to-use Pallet Builder extension app features an intuitive user interface that enables quick development and optimization of palletizing jobs. The included product database is scalable to meet your business needs, with guided prompts for cell configuration as well as pallet pattern setup and programming. This no-code platform is ideal for small- to medium-sized enterprises with little to no programming experience.
With support for a large number and variety of cases, Pallet Builder is easily customizable to accommodate specific system requirements, providing general functions, including:
Cell definition: Supports multiple infeeds, build stations and dispenser stations (for slip sheet separators). The interface can support up to eight combined stations.
Product database: Defines product type (case, pallet, separator) including product dimensions, mass, and label position.
Gripper definition: Accommodates multiple grippers and end-of-arm tooling types that can be defined with empty and loaded tool file reference, easily adjusting for product weight variation.
Single pick and place: Facilitates single pick tasks where a single product in the same orientation arrives on an infeed, as well as single drop positions with selectable label orientation.
RobotPro
When it is time to perform maintenance or fix a problem, RobotPro is the solution. A tool for performing alarm code troubleshooting, as well as robot preventive maintenance and repair procedures, RobotPro can be used as a detailed guide for maintaining the high performance you expect from your Yaskawa Motoman robots. One of the most comprehensive robot maintenance solutions in the industry, RobotPro provides the following features:
Descriptive test and repair procedures with illustrative graphics
Step-by-step instructions
Preventive maintenance schedules
Troubleshooting procedures
Parts lists
Wiring diagrams
