Brandon Brownlee, Motion
The increasing cost of food and beverage machinery makes running equipment to failure not just impractical, but potentially devastating to your bottom line. However, there are solutions that can lead to significant savings, and an often overlooked one is implementing an effective lubrication program. A well-structured program delivers a trifecta of benefits: reduced downtime, a cleaner and safer work environment, and easier compliance with the stringent regulations of the food processing industry.
Moving beyond basic lubrication, many companies find even greater returns by integrating lubrication into a comprehensive reliability-centered maintenance program. This approach, built on measurable goals, timely execution and consistent discipline, provides a framework for continuous improvement and drives significant payback. This focus on lubrication empowers you to achieve optimal asset health, consistent production output and the holy grail of zero downtime.
Myth BustersMore grease does NOT equal better lubrication. Think of it this way: Running through a kiddie pool at your local swimming pool is a breeze, but try that in the deep end, and you’ll barely move. The same principle applies to bearings or gearboxes overloaded with oil or grease. Excess lubricant, just like insufficient lubricant, leads to excessive heat buildup. Overgreasing also forces lubricant past seals, causing messy spills and potential contamination. A compromised seal becomes an entry point for contaminants, a major concern in sanitary environments. In both scenarios—too much or too little grease—component and machinery lifespan is significantly reduced. |
Apologies to William Shakespeare for contorting his line from Hamlet. While the decision “to lube or not to lube” might seem straightforward, developing and maintaining an effective program requires planning, dedication and an initial investment. However, the return on investment is undeniable: Lubrication programs consistently save money and reduce waste. Don’t wait for a contamination incident, regulatory action or equipment failure to force your hand. Protective lubrication is the key to keeping your assets producing, healthy and profitable.
Once the decision to implement a new lubrication process is made, assembling a cross-functional team is critical. The team should include representatives from maintenance, operations, engineering, and even your lubricant and equipment suppliers. The initial meeting serves as a crucial discovery phase, allowing the team to assess the current state of lubrication practices and define desired outcomes. Remember, clearly defined objectives are essential for achieving success.
This process is key to identifying and training dedicated, full-time lubrication technicians. Lubrication is not a task to be relegated to part-time or light-duty roles. It demands a specialized skillset, honed through comprehensive training and ongoing development, ensuring these technicians can effectively maintain the health of your assets.
This is where your cross-functional team shines and third-party partners bring their expertise. Focus on:
Proper storage and dispensing are crucial for maintaining lubricant integrity, promoting safety and ensuring efficient application.
Protecting the environment and complying with regulations are integral to a successful lubrication program.
Remember, minimizing should be a primary objective of your lubrication program. Following best practices for lubrication selection, application and storage, along with utilizing tools like automatic lubricators, can significantly reduce waste generation.
Elevate your lubrication program by investing in comprehensive training for your team. Partner with a reputable organization that can tailor a program to your plant’s needs and goals. This will empower your team with enhanced skills and credibility, and ultimately deliver a strong ROI.
Strive for comprehensive certification across your lubrication team. Organizations like the International Council for Machinery Lubrication (ICML) and the Society for Maintenance & Reliability Professionals (SMRP) offer valuable certifications in machinery lubrication, oil analysis and best practices for maintenance and reliability. A well-trained team is essential for building a world-class lubrication program.
Building a successful lubrication program requires ongoing effort and adaptation. Regularly review and adjust your plan to align with your plant’s evolving needs. Factors like new equipment installations, upgrades or decommissioning of older assets will necessitate modifications. Stay informed about changing regulations, whether due to plant expansions, relocations or general industry updates, to maintain continuous compliance. Remember, meticulous and consistent documentation is crucial for success.
This comprehensive approach to lubrication will contribute to improved asset health, a cleaner and safer food production environment and increased uptime. Prioritizing food safety benefits both your plant and consumers. By implementing these strategies and collaborating with your qualified lubricant and lubricant-equipment provider, you can establish a robust lubrication program as a cornerstone of your overall plant operations.
