Precision elastomer insert couplings offer vibration damping, easy installation, zero backlash transmission, and electrical isolation. Fitting a wide variety of drive applications including lift systems, conveyors, pumps, linear actuators, and high performance general power transmission. This split clamping hub design offers many advantages for machines where performance cannot be compromised. Two clamping screws per hub generate stronger shaft clamping pressure than traditional single screw designs. This can prevent slippage for smaller shafts at higher torque levels and increase the torque capacity per coupling size in general when used in keyless clamping configurations, while keyways are also available upon request.
