Modern drivetrains with voltage-source inverters not only offer advantages like, for example, variable speed operation, increased efficiency and higher dynamics, but also an increase in failures caused by induced parasitic currents.
The load carrying capacity of gear transmissions depends strongly on design, material and operation conditions. Modern analysis methods, e.g. finite element analysis (FEA), consider the above parameters with more or less sufficient accuracy. Yet it remains an ongoing challenge to account for backlash and manufacturing errors, despite a definite need to do so.
The 2017 Power Transmission Engineering Buyers Guide was compiled to provide you with a handy resource containing the contact information for significant suppliers of power transmission and related components.
As the old adage goes, "There is more than one way to skin a cat." In the early stages of any project, system designers are faced with choices; whether they are designing a new application or retrofitting an old one,
they need to determine what is the most efficient, economical and practical way of completing the task at hand. Though
there are usually at least two viable means to accomplish the task, the first step is always to review and weigh the merits of each option.
Standardized calculation methods such as ISO 6336 and DIN 3990 already exist to determine the load distributions on gears inside a planetary gearbox, but by their very universal nature, these methods offer varying results depending on the gearbox design. Double helical gears, in particular, can benefit from more specific, complex algorithms to reach a maximum level of efficiency. Double helical gears interact with the rest of the gearbox differently than helical or spur gears, and thus benefit from different analytical models outside the standardized methods. The present research project describes the algorithm to determine the load distribution of planetary gearboxes with double helical gears.
