In everyday life and in the technical fields we often discover that certain decisions are based on “scientific data” when, in fact, they are often founded on historic conclusions that have not been challenged or re-evaluated in a long time. One such common myth is that for a stable and well-tuned drive you should match the motor’s inertia to the load inertia, which is typically done using a gearbox. Two factors lead to that conclusion: a. there is an optimization formula using the time constant of the motor and the load torque that shows that the best acceleration will be achieved if the reflected load inertia matches the rotor inertia; and b. a PID controller, which was commonly used when electric servos entered the marketplace, tend to perform best and appear to be most stable when the inertia are close or matched.
GWJ Technology GmbH, a calculation specialist from Braunschweig, Germany, added new functions to the gear modules of its eAssistant web-based calculation software, which has been successful for more than 20 years.
Siemens Digital Industries Software and IBM recently announced they are expanding their long-term partnership by collaborating to develop a combined software solution integrating their respective offerings for systems engineering, service lifecycle management and asset management.
Welcome back to Part 2 of our inner ring and creep discussion. We left off with our creep calculation resulting in a 10.5 µm minimum inner ring fit to avoid creep. For the sake of making clean dimensions, let’s call it 10 µm on the lower end and the upper end is simply whatever your manufacturer can hold.
When selecting couplings for precise motion applications there are often questions about the most suitable approach for optimizing both performance and economy.
April 6, 2023
PTE will feature a variety of new component technologies online for bearings, motors, couplings, brakes, gear drives, and motion control systems leading up to Hannover Messe 2023 in Germany. Here is a preview of some bearings suppliers to check out if you're planning on attending the event online or in-person in April.
The new KISSsoft release 2023 comes with numerous novelties. Among others, Gear Mesh Frequencies (GMF) can now be calculated for cylindrical and bevel gears. GMF results are visualized in two different diagrams, i.e. GMF versus rotational frequency of the reference gear, and GMF versus amplitude.
