S. S. White Technologies is supplying the flexible shafts that transmit power to activate and synchronize the deployment of the Thrust Reverser Actuation Systems (TRAS) on 150 CFM International LEAP-1A turbofan engines that have been selected to power UK based Jet2’s latest order for up to 75 Airbus A321neo aircraft.
Stainless steel ASK Couplings from Miki Pulley feature a unique “sliced” body structure making them an effective low-cost corrosion resistant solution that can accommodate many types of misalignments. The stainless-steel design makes them ideal for use in food and chemical applications.
S. S. White Technologies is supplying flexible rotary shafts specifically designed to transmit rotary torque for the manual override on the Honeywell Aerospace Starter Air Valve.
