Thomson Industries, Inc., a leading manufacturer of linear motion control solutions, has introduced a family of compact linear systems that makes it easier for motion designers to implement complex applications in small spaces. Designers needing thrust and bearing support in a single, compact unit now have the flexibility to build such applications with versatile, time-tested components from Thomson.
Kalyani Mobility Drivelines (KMD) recently announced the introduction of a lineup of high-performance constant velocity (CV) driveshafts for electric vehicles (EVs) and other specialty vehicles.
Zero-Max did it again – three entirely new Extra-Duty Overhung Load Adaptor (OHLA) models. Based on decades of experience solving overhung load issues in the most demanding applications, the new designs feature a number of carefully chosen upgrades including spherical bearings, enhanced sealing technology, stronger shafts and a longer profile delivering increased operating life, heavy load capacities, and higher speed ratings.
Omni Powertrain Technologies has released information about its new electrohydraulic pump combination. The unit was developed for low voltage mobile applications and is ideally suited for the needs of hybrid equipment builders facing spatial constraints.
A high force-to-size ratio is just one of the many features of Moticont’s GVCM-051-089-02 Linear Voice Coil Actuator with Built-in Bearing. The actuator applies up to 66.4 N (14.9 lbs.) of continuous force and 210 N (47.2 lbs.) of peak force.
