igus has announced the winners of its 2024 vector awards, a biennial competition that honors bold, exciting projects that incorporate igus e-chain cable carriers made of high-performance plastics. A U.S. company, TDK RF Solutions, took the silver vector award for its automotive test rig.
Ruland Manufacturing now offers bellows and double disc couplings with bore sizes up to 1-3/4 in or 45 mm for use in systems with torque up to 1,4000 in-lbs. (158 Nm). High torque applications commonly found in precision semiconductor, solar, conveyor, and factory automation applications often use these shaft sizes. Ruland disc and bellows couplings accommodate all forms of misalignment, are zero-backlash, and have a balanced design for reduced vibration at speeds up to 10,000 rpm.
It’s common to hear the metaverse described as a 3D experience layer of the internet. The “industrial metaverse” is a more difficult concept to define. According to Forrester, it’s an umbrella term for a collection of different technologies. Some of those technologies have existed for years just waiting to come together.
Following a previous blog on the topic, Understanding the Industrial Metaverse, in this blog Stephen Graham, executive vice president and general manager, Nexus, takes an introductory look at the four building blocks, highlighting some of the key issues.
As engineers, we all know how to quickly create a sketch of a gearbox or transmission using a few lines. Using maybe black for shafts, green for bearings, blue for gears and red to indicate the power flow. We do this to remember a great idea, communicate with customers or to pass time waiting at an airport.
KISSsoft emulates this approach in a much more orderly fashion. Using only the mouse, complex schematics can be drawn and edited, thereby converting the structure of a gearbox into a logical and 3D model. The schematic in the Sketcher also serves as a navigation and visualization tool and is complemented by an overview of some of the key data (e.g. module and number of teeth) of the components making up the gearbox.
It's no secret that cycloidal gearboxes are important in mechanical engineering, especially when it comes to precision motion control and efficient power transmission. The gear systems differ from harmonic wave/strain wave gearboxes by using a cycloidal disk and needle bearings to transmit torque with minimum backlash, achieve high reduction ratios, and support substantial loads. This Sumitomo Drive Technologies blog will talk about single-stage and multi-stage cycloidal gearboxes.
Gear backlash in precision applications is a critical element of gear system performance. Too much backlash can result in inefficiencies of motion in the gear train and will ultimately damage a gear’s teeth. Too little can mean the gears bind up and cause excessive wear to the tooth’s surface and the root of the gear, or even the fracturing of a tooth. Establishing and setting the appropriate amount of backlash is essential in gear design and manufacturing, according to Berg, a Regal Rexnord Brand.
For this paper, the digital twin refers to a digital asset that exists alongside the physical asset during its operational life, providing insight into and feedback on the physical asset’s performance and health. Thus, the focus is on the DTI, with the potential to aggregate data into a DTA for the gearbox design being considered, and within the DTE set up by Hexagon.
In respect of the physical asset across its life, nothing is more important about its performance than its ability to function, i.e., reliability, and for CAE, nothing is of greater importance than to be able to predict the reliability of a product being designed. Thus, for this study, whilst gearbox noise, efficiency, and thermal behavior may be of interest, the primary interest is fatigue and reliability.
