The Canadian Manufacturing Technology Show (CMTS), Canada's largest industry event, makes its return at its new home – the Toronto Congress Centre – from September 25-28, 2023. Over 500 suppliers and original equipment manufacturers (OEMs), more than 8,000 manufacturing professionals and 250,000+ square feet of manufacturing excellence, housing 500,000+ pounds of live equipment are featured.
By definition, a spherical roller bearing (SRB) is a rolling element bearing that permits rotation with low friction and permits angular misalignment. SRBs consist of spherical rolling elements, an outer ring, a cage as well as an inner ring with two raceways inclined at an angle to the bearing axis. SRB technology has landed the component in unique applications including high pressure grinding rolls (HPGRs), pipelaying ships, Ferris wheels and even a Cold War–era marine espionage mission.
When engineers at Hoover Dam determined that the original cast iron lantern rings built into some of its turbines needed to be replaced, they were looking for a solution to help them overcome the corrosion issues they experienced with the cast iron.
Siemens Digital Industries Software recently announced that Tianneng Battery Group Co., Ltd. has selected the Siemens Xcelerator portfolio of industry software to help it drive innovation and enable digital manufacturing in new battery production.
NTN Bearing Corporation of America is pleased to announce the release of its latest product offering, the SNC plummer block. The SNC blocks are yet another heavy-duty mounted unit designed specifically to accommodate the rigors of applications within construction, mining, and other large-scale equipment applications.
A new version of the MESYS shaft and rolling bearing analysis software including new functionality is available. The bearing analysis software allows the calculation of the load distribution within the bearing and bearing life according to ISO/TS 16281 and it is integrated in a shaft system calculation with additional possibilities like modal analysis, strength calculation for shafts and interfaces to gear calculations. Currently the software is used by customers in 31 countries on 4 continents. The new version is now available.
This review of Ref. 1 summarizes the conclusions of test data and numerical simulations showing that Stribeck curves for counterformal contact are different from Stribeck curves for conformal contact.
Technical sales personnel use intelligent features to select suitable motor-gearbox combinations and run calculations based on customer-specific operating data. This provides obvious added value for the customer. Service lives, safeties, and expected loads can all be determined in a short time. Maintenance of the underlying database and the use of simulation tools make it possible to quickly and easily perform technical calculations without having to rely on a central calculation department. In less than a minute, the customer is provided with a data sheet which includes reliable statements about the gearbox based on these technical calculations.
