The following article explains the commonly used paint components and methods within the gearmotor industry, with a focus on electrodeposition coating (E-Coat). These processes will be described in general, with a closer examination of the E-Coat applications steps. Some pros and cons of each method will be presented along with comparative test results showing the benefits of E-Coat.
