If torque conversion with high gear ratio, compact installation space and 90-degree axis-crossing angle is needed, often worm gears are used. Due to their high power density and sliding speeds within the tooth contact, frictional heat and thermal stresses are higher compared to helical, bevel and hypoid gears, and thus the thermal load capacity of worm gears is lower.
The industrial arts of mechanical engineering are all around us and seen in many forms and technologies. Of greatest interest is how these wonders are designed, constructed and used. From the smallest home appliance to the behemoths used for outsize building and excavation projects.
