For a 5-megawatt wind turbine prototype,
aerodyn employs the latest control and software technologies, including a comprehensive PC-based control solution and the new modular TwinCAT Wind Framework. The TwinCAT Wind Framework features the latest software engineering and Big Data applications to extend current Industry 4.0 concepts to the wind energy industry. The modular software supports, for example, the direct provision of sensor data to the operator’s database, and in general enables the easy adaption of the wind turbine operation management to future requirements.
Although David Korins had an impressive resume
of Broadway, film, television and music
credits, the New York-based production
designer had something to prove when interviewing
for the pop culture phenomenon
Hamilton. “I prepped for the interview like crazy, sketching
out my ideas, presenting a scene breakdown, basically
doing everything I could short of begging for the job,” Korins
said. “Lin Manuel Miranda (the show’s creator and star) had
developed an incredibly effective blueprint. I just wanted the
opportunity to help tell his story.”
