Without the sun, there would be no
Earth and no life. However, our knowledge about our home star is still very limited. This is about to change. In 2018, the European Space Agency (ESA) will send its Solar Orbiter into space, equipped with a thick heat
shield.
A reader asks: I've determined that a stainless steel bearing is the best option for my application. I'm being asked to specify the grade of stainless steel in my product design. I'm not sure which grade to select and specify. Can you help?
"Well begun is half done," a quote that most reference materials attribute to Aristotle, certainly applies when selecting mechanical power transmission
products. A selection process that is well thought out at the start can ensure that the product selected will be properly sized and appropriate to the application at hand.
Mounted ball bearings are everywhere in industrial applications. They serve critical roles in keeping a manufacturing operation running smoothly and in ensuring that equipment functions properly and reliably. So why might it be advisable to spend significantly more for a dimensionally
comparable bearing from one supplier versus another?
