The ball screw drive is an assembly that
converts rotary motion to linear motion
and vice versa. The ball screw drive
consists of a ball screw and a ball nut
with recirculating ball bearings...
In most cases, industrial power transmission calls for flexible rather than rigid couplings in order to forgive minor shaft misalignment. For that reason, this article will focus solely on the selection of flexible couplings.
In an industrial application, equipment
uptime is vital for on-time performance and profitability. The rotating members of industrial machines are subject to the highest degree of wear and are more susceptible to failure than non-moving parts. Bearing surfaces are the most critical and often the most expensive portion of the rotary assembly; it is
imperative to protect these components. The primary protector of these components is the industrial seal.
Robots are everywhere these days—
bots in the factory, bots in space, bots at the airport, bots in the movies and much, much more. But robots in the operating room?
