QBC Introduces BETEX Cone Heater for Bearings December 21, 2017 Quality Bearings & Components, a distributor of the world’s leading bearing manufacturers and bearing maintenance equipment int...Read More
SKF Simulation Software Gives Engineering Tool to Customer Base December 20, 2017 SKF SimPro Expert is an advanced simulation software tool developed in-house by SKF to maximize support for, and co-operation with, its c...Read More
Bonfiglioli BSR Synchronous Reluctance Motors Offer Higher Power and Efficiency December 19, 2017 The new range of Bonfiglioli’s BSR synchronous reluctance motors reaches efficiency class IE4 at the same stator length as the four...Read More
Dunkermotoren Expands Servomotor Offerings December 18, 2017 With more than 100,000 sold units, the BG 65 (S) from Dunkermotoren is probably the most sold industrial DC servomotor with completely in...Read More
Matrix SMB Range Offers Reactive Market Solution December 15, 2017 Matrix International has built on its formidable reputation for Servo Motor Brakes (SMB) with the introduction of its SMB range in standa...Read More
Steinmeyer Offers a Selection of Miniature Ball Screws December 14, 2017 Steinmeyer recently announced a new program to stock a selection of miniature ball screws. The samples are available now for immediate sh...Read More
Forest City Gear Expands Small Diameter ID/OD Grinding Capability December 13, 2017 Forest City Gear has expanded its capabilities for the hard finishing of smaller diameter gears with particularly tight ID and length tol...Read More
Rexnord Broadens its IIoT Smart Tag Solution Offering December 12, 2017 Rexnord is pleased to introduce the Smart Coupling, part of its growing portfolio of connected products featuring the IIoT Smart Tag Solu...Read More
Portescap Linear Actuator Offers High Degree of Accuracy and Repeatability December 11, 2017 Portescap introduces the new 35DBM high power Stepper Can Stack Linear Actuator. This 35 mm linear stepper motor offers an enhanced desi...Read More
KISSsoft Adds Plastic Materials Manager Function December 6, 2017 It is often the case that plastics manufacturers don't provide any data that is relevant for calculations when they supply their prod...Read More
