VCI bags allow auto parts manufacturers and suppliers to eliminate greasy rust preventatives and opt for the dry protection of VCI film instead. Unfortunately, some VCI bags are doomed to failure, leading to the very corrosion that the VCI bag user was trying to prevent. To avoid these negative consequences, Cortec shares the best path to making sure your next VCI bag is the corrosion solution and not the problem.
Designing linear motion systems for washdown applications requires careful component selection to solve problems associated with contamination as well as liquid and chemical interactions.
December 1, 2023
This article examines the sound engineering practices and design principles needed to ensure the performance of mechanical linear motion components in sanitary washdowns or chemically cleaned environments. Relevant regulations and agencies, washdown-compatible materials, and best mounting practices and motion components for washdown applications are also discussed.
KUKA Robotics will spotlight a pair of innovative mobile robots March 11-14 in Booth B4003 at Modex 2024 in Atlanta. The KUKA KMP 1500P autonomous mobile platform and the KUKA KMP 600-S diffDrive mobile platform automated guided vehicle (AGV).
Regal Rexnord Corporation will feature an Automated Guided Vehicle (AGV) concept controlled by Kollmorgen that is equipped with ModSort technology at Pittsburgh Robotics Discovery Day, Booth 224. The show will take place at the David L. Lawrence Convention Center on November 16, 2023.
Digital transformation is one of the most effective approaches to help today’s CPG companies solve productivity and sustainability challenges. There are new and emerging automation technologies that CPGs can integrate within production lines to reduce energy consumption, streamline processes, increase machine availability and drive new levels of productivity and sustainability.
Automation specialist B&R is using this year's PackExpo exhibition in Las Vegas to feature open solutions with Codian robot mechanics, now integrated and rebranded within B&R. The Codian portfolio of delta configurations, including class-leading hygienic models, is open to any control platform and can be incorporated into any machine configuration. B&R's Machine-Centric Robotics solution combines Codian mechanics and B&R controls to offer machine builders and manufacturers single-source robotics and automation for precise synchronization and ease of engineering – ideal when implementing highly flexible packaging solutions.
Conveying parcel delivery with no system downtime is accomplished with speed and accuracy using Miki Pulley CSZ Clutches. Conveyors continuously operate via servomotor power by way of a V-belt. The system automatically switches on/off as programmed when engaged by the CSZ Clutches.
Trade show and event season is upon us. This issue we feature several upcoming shows that are extremely important in terms of mechanical power transmission components and the technology of motion control.
