Edilservice from Tuscany (Italy) has joined the Mollo network as of November 1, 2023. It's headquartered in Monteriggioni, Siena, and now becomes the 54th active Mollo center in Italy and the 5th in Tuscany.
Moticont has released the GVCM-022-013-01 Linear Voice Coil Servomotor. This compact .875 in. (22.2 mm) diameter high speed, high force-to-size linear motor features high accuracy and high repeatability when operated in a closed loop as a DC servo motor. This brushless servo motor is clean, quiet and has long life, low mass and high acceleration/deceleration for high throughput.
Forest City Gear is proud to share that Mindy Young, shareholder and third daughter of Fred and Wendy Young, has been invited to join the Rockford Symphony Orchestra Foundation Board. Since 2007, the Board has been dedicated to financing and supporting the mission of the Rockford Symphony Orchestra.
Randy Stott, publisher of Power Transmission Engineering and Gear Technology magazines, recently sat down with Norm Parker, technical fellow and technical manager for Torque Transfer Systems at Stellantis, to discuss bearing technology during the Motion + Power Technology Expo in Detroit.
How does one accurately examine the components in a robotic arm or prosthetic leg? There’s not exactly time (nor space) to set up multiple cameras to track deformation or changes in shape of soft components.
Designing linear motion systems for washdown applications requires careful component selection to solve problems associated with contamination as well as liquid and chemical interactions.
December 1, 2023
This article examines the sound engineering practices and design principles needed to ensure the performance of mechanical linear motion components in sanitary washdowns or chemically cleaned environments. Relevant regulations and agencies, washdown-compatible materials, and best mounting practices and motion components for washdown applications are also discussed.
A calculation platform suitable for all areas of gearbox development
December 1, 2023
Developing a new gearbox series is costly and time-consuming. This is especially true in marine propulsion, as classification society certifications must be achieved in addition to the required verifications. For this reason, Reintjes offers the same drives for various types of ships. In gearbox development, this means that each application requires different loads and usage profiles, with different service lives and maintenance intervals. Thus, each drive must be designed and calculated with advance consideration of every possible profile.
MiR Insights from Mobile Industrial Robots (MiR) is the 2023 winner of the New Equipment Digest Innovation Award in the automation category. As shared on NewEquipment.com this week, MiR Insights is a cloud-based software that empowers customers of MiR’s autonomous mobile robots to optimize the performance of their fleets and minimize downtime with data-driven intelligence.
The 2023 SPS trade fair in Nuremberg represented an important opportunity for Bonfiglioli to showcase its experience and expertise for industrial automation. This included mechatronic solutions specifically designed for packaging, intralogistics, robotics and IoT applications.
