With the CP150 compact controller, the wait for the electronics to start up again after the engine is shut down for a short time is completely eliminated. This saves time and increases productivity in everyday work. Operators can eliminate the wait and also decrease emissions with the CP150, reducing their environmental footprint. B&R uses the vehicle's battery for the standby function.
Digital transformation is an ongoing process so we can expect to see this year's breakthrough trends continuing to shape society into next year. But how will these trends impact robotics and automation and what can the manufacturing industry expect to see next year?
Shaft collars and mounts that can be adjusted without tools, plus handles
and thumb screws to convert standard shaft collars to quick-adjust types,
have been introduced by Stafford Manufacturing Corp. of Wilmington, MA.
Stafford Quick-Adjust Products feature the Flip-Lok with a split hub and
an integral adjustable clamp, Staff-Lok Lever-Actuated shaft collar, and
the Python Flange Mounting Collar with a 6-hole bolt pattern and keyway.
Suitable for a wide range of linear and low RPM rotary applications, these
quick-adjust products can be easily repositioned by hand without tools.
Drive specialist Flender has received the Supplier Excellence Recognition Award 2023 from U.S. machinery manufacturer Caterpillar. Flender received the award for maintaining 95 percent delivery
reliability and zero defects. This achievement is awarded only to the top suppliers of Caterpillar. It
positions Flender as a top supplier for its global Aftermarket (Reman) Division business.
Atlanta Gear Works (AGW) is expanding its support staff by hiring its first Human Resources Specialist, a new position created to meet its expanding HR needs, previously managed by the company’s chief financial officer.
Ruland has released mountable shaft collars with face holes for applications where the shaft collar needs to be directly mounted to a component such as a pulley, sprocket, or metallic plate. The shaft collars are available with drilled face holes that give the user flexibility in mounting hardware, or tapped holes that match the standard screw threading of the collar for ease of installation.
Verusen, the global MRO materials intelligence innovator, recently announced that it was named the winner of two leading technology awards for supply chain industry excellence. Verusen was recognized as a winning company in the ‘Top Tech Startup’ category for the supply chain and logistics space by leading industry publications Food Logistics and Supply & Demand Chain Executive. Verusen also won a Top Software & Tech Award for its AI-powered Trusted Supply in the Procurement/ERP category.
Portescap introduces the 60ECF brushless DC slotted flat motor, the newest frame size to join its flat motor portfolio and a significant expansion of its brushless flat technology capabilities. This 60mm BLDC motor features a 38.2mm body length and an outer rotor slotted configuration with an open body design, allowing it to deliver improved heat management in a compact package.
Siemens Digital Industries Software has announced that Space Machines Company (SMC), an Australian space on-orbit services and logistics startup, has used the Siemens Xcelerator portfolio of industry software to design and build the Optimus Orbital Servicing Vehicle. One of the largest commercial spacecrafts being designed, manufactured, and assembled in Australia, is in development at the University of Technology Sydney’s Tech Lab.
China is leading the world in the construction of solar, wind and thermal power plants to support its increasing demand for electrical energy. For those that use steam turbines, boiler feed pumps (BFPs) are a crucial asset and selecting the best design to suit the needs of an individual station can have many benefits. When a recent project needed some of the largest start-up BFPs available, Sulzer was selected as the preferred supplier.
