eSOL has announced that it will release new versions of its CC-Link IE TSN SDK in next spring. The eSOL CC-Link IE TSN SDK supports the open industrial network, CC-Link IE TSN, defined by the CC-Link Partner Association.
The Production System P-50 is designed to be the fastest way to 3D print metal parts at-scale. Powered by Desktop Metal's Single Pass Jetting technology, the P-50 can achieve speeds up to 100 times those of legacy powder bed fusion additive manufacturing technologies and enable production quantities of up to millions of parts per year at costs competitive with conventional mass production techniques.
Opto Diode Corporation, an ITW company, introduces the AXUV100G, a 100 mm x 100 mm active area electron detection device specially designed for use in radiation detection applications.
Cortec Corporation recently announced its acquisition of Cortec Southeast Asia (CSEA) offices in Singapore. CSEA is now a wholly owned subsidiary of Cortec Corporation. This development promises to improve service and support to customers in Southeast Asia due to a direct connection with Cortec headquarters in Saint Paul, Minnesota.
Bosch Rexroth has opened a new customer innovation center near Austin, Texas. The facility will provide a unique technology development experience for Bosch Rexroth factory automation customers from multiple industry segments, including electric vehicle manufacturing, battery production, consumer packaged goods and semiconductor manufacturing. The new innovation center is the latest in a series of expansions and investments Bosch Rexroth is making in North America, including a new plant in Queretaro, Mexico, and an expansion of its operations in Charlotte, N.C.
Gasoline engines, pumps, generators and other machines operating in rugged environments require long-lasting components to ensure successful performance. Clutches designed with durable materials can prevent breakdowns, which would otherwise lead to expensive maintenance and downtime. One example of a ruggedized clutch — the Carlyle Johnson's EPC multiple disc electric pulley clutch — consists of a standard electromagnetic multiple disc design and utilizes oil shear to enhance service life.
The Ogura MCNB-HS Series power-off spring applied brakes have oversized bores to allow wires to pass through the shaft’s hollow bore. They accommodate encoders, cables, hoses, shafts, and tools. The ratio of the brake’s field core diameter to outer diameter is leading the industry.
