In December 2023, ABB Electrification Norway AS signed a contract with LIS, Movu Robotics distributor in Norway, to install Movu's escala order fulfillment solution in its production premises in Skien, Norway.
Bosch Rexroth and Modine are collaborating to bring Modine EVantage thermal management systems to the Bosch Rexroth portfolio of eLION products for electrified off-highway machinery worldwide. Together, Rexroth eLION systems with Modine EVantage thermal management systems advance the electrification of customer platforms in the off-highway segment by delivering low emissions and high-performance EV technology.
SKF has been awarded a Platinum Medal by EcoVadis, one of the most trusted providers of sustainability ratings for use in supply chains. This prestigious recognition places SKF in the top one percent among the more than 100,000 companies assessed worldwide for its commitment to sustainable business practices.
CES 2024 boasted 4,300+ exhibitors, including a record 1,400+ startups from around the globe. The event continued to showcase the innovative trends shaping our future.
IKO International introduces its CFC…B Series of short stud-type cam followers. These new cam followers have a unique mounting structure that solves space limitations that often exist on the stud side of the assembly region, thereby satisfying mounting requirements without sacrificing performance.
When it comes to twisting and bunching wire and cable, consistency is key. For example, the amount of insulation required for residential wiring depends on the wire’s lay — the distance between its twists, which is also known as the pitch. Without tight control during the wire bunching process, lay variations occur. As a result, the wire will require more insulation than necessary, raising its cost. A differential gearbox can drive rotating components in a single-twist buncher to provide a more uniform lay, using less power at a lower cost than a two-motor approach.
The Association for Advancing Automation (A3) celebrates its 50th anniversary in 2024. The global advocate for the benefits of automation now represents more than 1280 member companies as it promotes automation technologies and ideas that transform and redefine the business environment.
Velo3D, Inc. announced Kratos SRE, Inc., a subsidiary of Kratos Defense & Security Solutions, Inc., has acquired a Velo3D Sapphire printer to support Kratos’s technology development and ability to rapidly, reliably, and affordability address defense industry customers’ evolving requirements.
