NSK has developed HTF-SRM Ball Screws, a high-speed, heat-resistant version of its high-load drive ball screws, ideal for high-cycle, thin-wall molding in electric injection molding machines.
Boston Gear recently introduced the next generation of its 700 Series Worm Gear Speed Reducer. The SS700 Gen2 stainless steel speed reducer is an evolution of its first-generation series that has served the food and beverage industry for over 10 years.
Velo3D, Inc. has announced its Sapphire family of 3D printers are the first to achieve the U.S. Department of Defense’s (DoD) Green-level STIG (Security Technical Implementation Guide) Compliance. The certification allows Sapphire printers to be connected to the DoD’s Secret Internet Protocol Router Network (SIPRNet) and gives customers the confidence their metal 3D printers are hardened against potential cyberattacks.
VCI bags allow auto parts manufacturers and suppliers to eliminate greasy rust preventatives and opt for the dry protection of VCI film instead. Unfortunately, some VCI bags are doomed to failure, leading to the very corrosion that the VCI bag user was trying to prevent. To avoid these negative consequences, Cortec shares the best path to making sure your next VCI bag is the corrosion solution and not the problem.
AutomationDirect has added more ProSense XTH2 series fixed range, head-mounted temperature transmitters to their lineup of temperature transmitters/signal conditioners. The XTH2 series fixed-range transmitters are for Type Pt100 3-wire RTDs and are ready to use out-of-the-box with pre-configured measuring ranges up to 500°F (260°C).
SKF has expanded its portfolio of Condition Monitoring solutions with the SKF Enlight Collect IMx-1-EX sensor solution. Wireless monitoring of assets helps predict machine failure before it can escalate into a serious problem, such as an unscheduled shutdown. This can deliver multiple benefits, including reduced costs and a more sustainable operation of equipment.
Intellidrives Theta 2 theta stage consists of two rotation stages arranged in such a way that axis of rotation for both the stages are same. Both stages have preloaded ball bearing guides for wobble free rotation and positioning. 360° limitless movement is possible for inner and outer stages.
The Ohio State University was joined by Ohio Lt. Gov. Jon Husted, congressional leaders, Honda, Schaeffler Americas and JobsOhio officials recently to announce the creation of a new battery cell research and development center.
Siemens Digital Industries Software recently released HEEDS AI Simulation Predictor software and Simcenter Reduced Order Modeling software. These tools empower engineers to tackle the most complex challenges manufacturers face, delivering predictive performance with speed, precision, and efficiency.
