Opto Diode Corporation, an ITW company, introduces the AXUV100G, a 100 mm x 100 mm active area electron detection device specially designed for use in radiation detection applications.
Gasoline engines, pumps, generators and other machines operating in rugged environments require long-lasting components to ensure successful performance. Clutches designed with durable materials can prevent breakdowns, which would otherwise lead to expensive maintenance and downtime. One example of a ruggedized clutch — the Carlyle Johnson's EPC multiple disc electric pulley clutch — consists of a standard electromagnetic multiple disc design and utilizes oil shear to enhance service life.
The Ogura MCNB-HS Series power-off spring applied brakes have oversized bores to allow wires to pass through the shaft’s hollow bore. They accommodate encoders, cables, hoses, shafts, and tools. The ratio of the brake’s field core diameter to outer diameter is leading the industry.
Optimal Engineering Systems, Inc. (OES) has released four new high resolution, high repeatability XY Alignment Stages. The AU200-120x120 Alignment Stages feature 120 mm (4.724 in.) of travel in both the X and Y axes. These new low profile 87 mm (3.425 in.) high XY stages, have a 188 mm x 188 mm (7.401 in. x 7.401 in.) open aperture. Easy integration of tooling and fixtures is facilitated through a precision series of threaded mounting holes.
Siemens Digital Industries Software announced that the Luna Rossa Prada Pirelli America's Cup team is using the Siemens Xcelerator portfolio of software and services to design, simulate and optimize its racing yacht for the forthcoming America’s Cup challenge (37th America’s Cup).
Kalyani Mobility Drivelines (KMD) recently announced the introduction of a lineup of high-performance constant velocity (CV) driveshafts for electric vehicles (EVs) and other specialty vehicles.
Rolling bearing life depends on the contact stresses that occur between the rolling elements and the raceways. Contact stresses are calculated from contact loads, which in turn depend on the external loads acting on the bearing and the precise internal geometry of the bearing.
