By definition, a spherical roller bearing (SRB) is a rolling element bearing that permits rotation with low friction and permits angular misalignment. SRBs consist of spherical rolling elements, an outer ring, a cage as well as an inner ring with two raceways inclined at an angle to the bearing axis. SRB technology has landed the component in unique applications including high pressure grinding rolls (HPGRs), pipelaying ships, Ferris wheels and even a Cold War–era marine espionage mission.
A new version of the MESYS shaft and rolling bearing analysis software including new functionality is available. The bearing analysis software allows the calculation of the load distribution within the bearing and bearing life according to ISO/TS 16281 and it is integrated in a shaft system calculation with additional possibilities like modal analysis, strength calculation for shafts and interfaces to gear calculations. Currently the software is used by customers in 31 countries on 4 continents. The new version is now available.
IKO is pleased to announce that Jeff Williams has joined the company as national distribution sales manager. Contributing to IKO's efforts to build and enhance relationships with valued customers, Williams will be based in Parsippany, NJ and will work closely with distributors and sales teams.
The Timken Company has acquired the assets of American Roller Bearing Company (ARB), a North Carolina-based manufacturer of industrial bearings. ARB's offerings join Timken's industry-leading portfolio of engineered bearing solutions. ARB, which boasts a large U.S. installed base and strong aftermarket business, generated sales of more than $30 million in 2022.
Next-generation technology—everything from the electrification of vehicles to e-motors, bearings, mechatronics, and thermal management—was discussed during the Schaeffler Symposium 2022 in Detroit. I sat down with Jitesh Modi, director of engineering, during the event to discuss the “reinvention” of bearings for EV applications.
NTN Bearing Corporation of America is honored to announce that effective December 31, Kevin Judge will retire from his role as brand ambassador for NTN’s Automotive Aftermarket business unit, formally ending his professional tenure with NTN.
Bearing calculations from Timken can now be easily generated in KISSsoft for the software’s registered users. Although the data is not visible in KISSsoft, it can be used in the background for calculation and design purposes.
NTN has announced the receipt of a 2022 Content Excellence Award from the Automotive Content Professionals Network (ACPN). BCA Bearings received the Silver Award for its Web-Based Catalog at the 2022 ACPN Knowledge Exchange Conference.
