Precise positioning of semi-conductor wafers during SCARA assembly operations requires instantaneous braking and holding power while minimizing heat in the system. The latest compact and slender Miki Pulley BXR-LE brake models provide the needed perfectly controlled braking in a confined area of the system using minimal power.
There is no compromise to safety in robotic applications. Lightweight robots or collaborative robots (cobots) are capable of complex and unexpected movements and need to stop immediately ensuring the safety of human operators. This is where smart couplings and smart brakes provide intelligent flexibility and guidance.
Motion Industries, Inc. recently named
Chris Cleland to senior vice president of strategy and markets, effective immediately.
Cleland’s career spans over 25 years in consulting,
strategy, marketing, branding, e-commerce, business
development, and transformation.
Efficient power-saving braking for mobile robots is critical to minimize battery charging downtime. The new larger size Miki Pulley BXR-LE brakes are ideal for factories and similar applications using mobile robots.
Unless you work for a major network, you’ve probably never heard of them. But without the efforts of Drew
Farrow and the team at ShowFab many of your favorite Broadway shows, news programs, and broadcast
sporting events would not be possible. That’s because there’d be no colorful backdrops, no glitzy displays,
and no lights or cameras moving silently overhead.
The reason they’re silent? Nord Drivesystems whose gearmotors position the massive scenery seen
moving in and above the sets of The Today Show, Fox News, Fox Sports, The NFL Network, and
NewsNation, to name a few.
A worldwide manufacturer of many types of plastic has manufacturing facilities around the world, including one in the southeast that makes PVC stretch film. Imagine the film used to wrap meat at your local neighborhood grocery store, or that you might use to keep leftovers fresh for later in the week. Although the plant is designed for precision and automation, sometimes mechanical components derail those plans and require operator interaction to correct the components shortcomings. The clutch-brake on a turret winding system was not precise, which not only required operator interaction but also caused downtime. Replacing the dry clutch brakes with Force Control Oil Shear clutch brakes eliminated downtime, increased accuracy and repeatability, and slashed operator involvement – all while increasing throughout.
Conveying parcel delivery with no system downtime is accomplished with speed and accuracy using Miki Pulley CSZ Clutches. Conveyors continuously operate via servomotor power by way of a V-belt. The system automatically switches on/off as programmed when engaged by the CSZ Clutches.
