In December 2023, ABB Electrification Norway AS signed a contract with LIS, Movu Robotics distributor in Norway, to install Movu's escala order fulfillment solution in its production premises in Skien, Norway.
Mark Ruberg, packaging industry manager at Beckhoff USA, will serve another four-year term on the PMMI Industry Relations Committee. As an experienced packaging industry expert, Ruberg has been active throughout his career with various committees and work groups at PMMI – The Association for Packaging and Processing Technologies.
A growing number of companies are adopting robotic solutions in their logistics processes. They provide far greater flexibility than conventional automated handling systems, and can seriously boost productivity, throughput and operational accuracy, even in ‘steady state’ operations. Pallet and bin shuttle systems for automated storage and retrieval are a prime example. With modular design, acting as a set of building blocks to minimize complexity and cost of upgrading, these systems are highly scalable installations can start small and then expand or, if needed, they can downsize just as easily.
VCI bags allow auto parts manufacturers and suppliers to eliminate greasy rust preventatives and opt for the dry protection of VCI film instead. Unfortunately, some VCI bags are doomed to failure, leading to the very corrosion that the VCI bag user was trying to prevent. To avoid these negative consequences, Cortec shares the best path to making sure your next VCI bag is the corrosion solution and not the problem.
Designing linear motion systems for washdown applications requires careful component selection to solve problems associated with contamination as well as liquid and chemical interactions.
December 1, 2023
This article examines the sound engineering practices and design principles needed to ensure the performance of mechanical linear motion components in sanitary washdowns or chemically cleaned environments. Relevant regulations and agencies, washdown-compatible materials, and best mounting practices and motion components for washdown applications are also discussed.
KUKA Robotics will spotlight a pair of innovative mobile robots March 11-14 in Booth B4003 at Modex 2024 in Atlanta. The KUKA KMP 1500P autonomous mobile platform and the KUKA KMP 600-S diffDrive mobile platform automated guided vehicle (AGV).
Regal Rexnord Corporation will feature an Automated Guided Vehicle (AGV) concept controlled by Kollmorgen that is equipped with ModSort technology at Pittsburgh Robotics Discovery Day, Booth 224. The show will take place at the David L. Lawrence Convention Center on November 16, 2023.
